ENERGEN Cartridge Valve Converts Hydraulic Power to Electric Power
Sun Hydraulics has introduced the ENERGEN cartridge valve to convert hydraulic power into electrical power. As electrification increases in applications still requiring use of hydraulics, such technologies can help bring together fluid power and electric systems.
ENERGEN features an integrated generator to convert pressure differentials into electricity, allowing it to provide local and remote electrical power generation. The valve provides an output power capacity of 40W, enabling it to provide reliable power for sensors, wireless communication, and smart monitoring without the need for external energy sources. It supports electrical power requirements of remote monitoring and predictive maintenance, enhancing system intelligence and reliability.
The valve is designed to fit Sun Hydraulics’ compact T-16A cavity, enabling seamless integration into existing hydraulic systems while operating within standard flow and pressure ranges. ENERGEN can be used in both mobile and industrial hydraulic applications.
Additional features of the ENERGEN cartridge valve include:
- maximum rating of 200 psi (14 bar) at port 2
- ability to withstand pressures up to 5,000 psi (350 bar)
- upright or horizontal installation options
- CE and NFPA test standard T2.6.1 R2014 compliance
- higher electrical loads and lower Port 2 pressure reduce leaks
- 3,000-hour lifespan and durable construction for long-term performance in harsh environments
Sara JensenSara Jensen
Facebook: @PowerMotionTech
