CONEXPO 2026: New Technology Launches
New hydraulic cylinder sensors, seals, electrification systems and other technologies for construction equipment applications will be launched at CONEXPO 2026.
CONEXPO-CON/AGG 2026, one of the largest construction industry events, is just a few short weeks away, taking place March 3-7 at the Las Vegas Convention Center.
Each edition of the triennial event provides a look at the latest equipment and technology launches for the construction industry. As this is an important customer segment for hydraulics, pneumatics and electromechanical technology suppliers, several are planning to showcase their latest developments at CONEXPO 2026.
Enerpac Debuting New Hydraulic Tools, Lifting and Transportation Systems
Enerpac, a developer of high-pressure hydraulic tools, is planning to introduce several new technologies at CONEXPO 2026.
Appearing at CONEXPO for the first time will be:
  • 600T capacity Enerpac SBL600 hydraulic gantry,
  • 60T capacity DTA by Enerpac automated guided vehicle (AGV) Smart Transporter,
  • 200T capacity SCJ-Series cube jacks,
  • battery-powered SC-Series and XC2-Series pumps,
  • PPH-Series joint pin puller and
  • E-mover skate system.
The company will also launch its first Battery Powered Split Flow Pump and next generation, newly designed 400T capacity Low Height Skidding Systems (LH400). Enerpac will offer demonstrations of many of these new technologies as well to show attendees how they can be used in their own operations to help with moving and servicing items.
Moog Showcasing Adaptive Electrification Management System
Moog Inc. plans to show its latest development for electric vehicles, the Adaptive Electrification Management System (AEMS) at CONEXPO 2026. AEMS is a modular system designed to help OEMs more easily electrify and automate their machines.
It is comprised of several components contained in a compact package, including:
  • a configurable controller,
  • DC/DC converter,
  • high-voltage distribution, and
  • single- and dual-axis inverters.
The system features a high-voltage busbar and shared coolant manifold to help reduce the number of cables and hoses required, simplifying assembly and maintenance. It manages multiple electric vehicle functions simultaneously with streamlined software architecture to enhance performance and reduce power loss. Built-in diagnostics provide consistent system monitoring for traction, steering, lifting, and more across machine platforms, aiding implementation for machine developers.
AEMS can be adapted to machines of various sizes, from 6-ton compact track loaders to 25-ton excavators, allowing an OEM to deploy a single electrification and software platform across multiple lines, if desired, which helps to reduce development time and costs.
“AEMS reduces testing and configuration time by up to eight hours and supports over-the-air software updates post-production to add new features seamlessly,” said Dr. Nate Keller, Moog’s Strategic Business Manager, in the company’s press release announcing the system’s introduction at CONEXPO.
Watch our video interview with Keller to learn more about the role electrification can play in aiding the implementation of automation.
Per Moog, AEMs is already being utilized in some prototype machines and previous versions were used in the Bobcat T7X, CASE 580 EV fully electric backhoe and other construction machinery.
Rota Introducing New Position Sensor for Hydraulic Cylinders
Rota Ltd. will introduce its new ELU Series external sensor technology for hydraulic cylinders. Due to recent technology advancements, the sensor’s magnet is now up to 88% smaller than previous versions which helps to reduce costs, weight and installation space.
Designed to provide position sensing, the company’s external sensor technology propagates a magnetic field through a carbon steel cylinder wall, enabling accurate analog or digital position reporting for cylinders. This eliminates the need to use traditional installation methods such as deep drilling which may not be possible or economically viable in some applications.
The new ELU Series sensor can be used in a range of applications, including construction equipment, agricultural machinery, transportation and more.
Sunnen Products Showing All-Electric Tube Honing
Sunnen Products Company — a developer of high-precision honing, bore sizing, and engine rebuilding equipment — will show its next-generation, all-electric tube honing solution for hydraulic cylinder repair and other industrial applications such as heavy equipment manufacturing.
The HTA Tube Hone features an all-electric drive to provide quieter operation as well as improved control and accuracy during bore reversals. It has a compact design to reduce floor space compared to traditional horizontal tube honing systems.
Features of the tube honing system include:
  • Siemens Servo Stroker Motor with Belt Drive for smooth and precise operation
  • spindle unit rated at 3 hp (2.24 kW) with adjustable stroker speeds from 5- 90 ft. per minute (1.5- 27.4 m per minute)
  • robust power for resurfacing and repair tasks at spindle speeds of 20-300 RPM
  • programmable auto tool feed system to aid efficiency and safety
  • stroker joystick for precise tool positioning and stroke length adjustment
  • load meter and universal V-block work holding system allow for real-time feedback and fast fixturing
  • compatibility with ANR-275 tooling minimizes tooling changeover costs.
Learn more about Sunnen's tube honing technology in the article "Rebuilding Cat machines simplified with cylinder honing."
Trelleborg Exhibiting New Sealing Technologies for Off-Highway Equipment Applications
Trelleborg Sealing Solutions will show several of its seal technologies for use with hydraulic and powertrain systems in construction and other off-highway equipment applications.
Among these will be the company’s new Stefa Cassette seals which are designed for use in tractors, construction equipment and other heavy-duty vehicles. The seals feature multiple sealing lips integrated into them as well as a protective metal casing and an internal sleeve to create a robust barrier against contaminants while retaining lubricants.
This design helps to protect the seal and other machine components from mud, water and abrasive debris that typically destroys conventional seal designs noted Michael Cook, Global Segment Director Off-Highway, in the company’s press release announcing its presence at CONEXPO 2026.
Additional technologies on display include Trelleborg’s seals and wipers for use in hydraulic cylinders, it’s HMF17 FlatSeal flat gasket for preventing leaks in equipment, and its H2Pro range of sealing materials which includes a new rubber for use in high-pressure hydrogen environments.
Read the article "Spotlight on Sealing Solutions for Fluid Power and Off-Highway" to learn more about seal technology for fluid power systems used in mobile off-highway equipment.
Sara Jensen
