CONEXPO 2026: Sensor, Electromechanical and Other Technology Exhibitors
As one of the largest events for the construction industry, CONEXPO-CON/AGG is filled with a wide range of technologies to see which are vital to the operation of construction equipment of various types.
In addition to the many fluid power components and systems that will be on display at CONEXPO 2026, there will be a wide range of other technologies often used directly with or in addition to hydraulics and pneumatics including sensors, filtration systems, lubricants, electromechanical components and more.
Learn More About CONEXPO 2026
Check out our other CONEXPO-related content to help prepare for this year’s show, including our list of fluid power exhibitors that will be in attendance, by visiting our dedicated CONEXPO 2026 page. And if you're not already, sign up for our newsletters to ensure you receive our special edition newsletter that will be sent each day of CONEXPO to help keep you up to date on new product launches and more.
Given component suppliers and machine designers are often bringing together a range of technologies to enhance the performance of construction equipment, it is important to understand the various options available. And what better place to see them than CONEXPO.
For the 2026 edition, show organizers have created a components concentration area, located on the second floor of South Hall of the Las Vegas Convention Center, where a large majority of component suppliers are located. However, there are many located in other parts of the show grounds as well.
So, below you’ll find our list of sensor, electrification and other technology suppliers exhibiting at CONEXPO 2026 likely to be of the most interest to those developing fluid power and other motion systems for construction equipment. We’ve included their booth numbers as well as a key and notes where necessary to help make finding them as easy as possible so that if you’re attending the show you can plan your time accordingly.
Sara Jensen
Facebook: @PowerMotionTech
