Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 9666newproducts 00000003454
Piston-sensing pressure switch
June 27, 2005
Model series 2PSH combines a durable piston-sensing element with reliable, time-tested switch mechanism, for performance in demanding high pressure and shock applications. Ranges from 200 to 10,000 psi. Comes with NEMA 4X, 12 and 13 housing, and ...
Model series 2PSH combines a durable piston-sensing element with reliable, time-tested switch mechanism, for performance in demanding high pressure and shock applications. Ranges from 200 to 10,000 psi. Comes with NEMA 4X, 12 and 13 housing, and one or two SPDT contact. Tested beyond 15 million cycles for long life. Designed for hydraulic punch presses, injection molding machines, high-pressure gas systems, etc. Uses carbide piston and spring energized PTFE seal for minimal seal wear and consistent performance.
Solon Manufacturing Co., (440) 286-7149, www.solonmfg.com
