Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads 2012 09 Tobul Piston Accumulators
Piston accumulators
Sept. 11, 2012
Full line of standard piston-type accumulators are selected based on physical dimensions, maximum allowable working pressure, and fluid volumes to best suit application. Available in wide variety of materials, seal configurations and materials, and fluid and gas port configurations.
Full line of standard piston-type accumulators are selected based on physical dimensions, maximum allowable working pressure, and fluid volumes to best suit application. Available in wide variety of materials, seal configurations and materials, and fluid and gas port configurations. Standard sizes from 2.375 to 24 in. diameter, 0.0063 to 200 gal capacities, and 2500 to 10,000 psi max working pressure.
Tobul Accumulator, (803) 245-5111, www.tobul.com
