Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 03 01 2008 79434tubehosejp 00000052009
Truck, bus hose systems
March 26, 2008
Hose and connector systems meet or exceed SAE specifications for heavy-duty applications, especially truck engines subjected to high heat and high pressures. They are manufactured using True- Bore technology instead of standard 100R5 ...
Hose and connector systems meet or exceed SAE specifications for heavy-duty applications, especially truck engines subjected to high heat and high pressures. They are manufactured using True- Bore technology instead of standard 100R5 requirement to ensure exact specifications in matching hoses and couplings. Coupling and crimper products are also available to provide tight and leak-free, port-to-port connections.
Gates Corp., Worldwide Fluid Power Div., (800) 777-6363, www.gates.com/truck-bus
