Eaton Aeroquip High-Pressure Hydraulic Hose
Aug. 12, 2007
Six-spiral Aeroquip GH466-32 hose has a constant working pressure of 420 bar for high-pressure spikes. It operates in temperatures to 120° C and meets EN856/100R15 with Class 0 cool-down leakage in accordance with SAE J1176. It also surpasses SAE ...
It also surpasses SAE J1405 by withstanding more than 2 million flex impulse cycles. It uses Aeroquip Internal Skive Crimp (ISC) fittings, which feature an internal and external skive design that separates the socket into three different zones — dampening, sealing, and wire trap.
Eaton Corp., Hydraulics Operations, (952) 294-7992, www.hydraulics.eaton.com
