Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 05 01 2010 85754filterelem 00000058364
Filter Elements
May 11, 2010
Edited by Mary C. Gannon SwiftGreen filter elements for return line applications feature a reusable machined aluminum bypass valve assembly and can be used as direct replacements for most filter elements. Because they can be used ...
SwiftGreen filter elements for return line applications feature a reusable machined aluminum bypass valve assembly and can be used as direct replacements for most filter elements. Because they can be used indefinitely with fresh filter elements, they reduce expenses while minimizing disposal volume. They use SwiftGlass micro- fiber glass filter media, which provides high levels of fluid cleanliness while maintaining low pressure drop characteristics. Elements are used on the return side of a hydraulic/lubrication circuit.
Swift Filters Inc., (877) 887-9438, www.swiftfilters.com
