Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 11 01 2007 76383leakdetect 00000048984
Leak-detection lamp
Nov. 21, 2007
Maxima ML-3500 ultraviolet light allows quick and accurate identification of fluid leaks. It delivers up to 10 times UV-A output of conventional high-intensity discharge lamps. It can be used with fluorescent dyes to detect leaks in ...
Maxima ML-3500 ultraviolet light allows quick and accurate identification of fluid leaks. It delivers up to 10 times UV-A output of conventional high-intensity discharge lamps. It can be used with fluorescent dyes to detect leaks in hydraulic systems. It has an inspection range to 30 ft and can function in direct sunlight. ML- 3500RS model is connected to a fully retractable, ratcheting reel with a 35-ft cord. ML-3500FL is a flood lamp for wider beam inspection. All models are available in 120, 230, 240, and 100 V.
Spectronics Corp., (800) 274- 8888, www.spectroline.com
