Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 63518products01 00000039454
Radial piston pumps
April 30, 2007
PFR high-pressure radial pumps now feature a 5-piston version that exhibits long life and low noise. Nine models come with displacements from 1.7 to 25.4 cm3/rev and maximum pressure to 350 or 500 bar. They are compatible with hydraulic oils, phosphate ...
PFR high-pressure radial pumps now feature a 5-piston version that exhibits long life and low noise. Nine models come with displacements from 1.7 to 25.4 cm3/rev and maximum pressure to 350 or 500 bar. They are compatible with hydraulic oils, phosphate ester, and water-glycol fluids and are available as single or through-shaft for direct coupling with vane pumps.
Atos s.p.a., +39 0331-922078, www.atos.com
