Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 43975 Products01 00000020104
Disc valve motors
Jan. 2, 2007
High-pressure 30 disc valve motors offer high starting torque efficiency, low pressure drop, and smooth two-speed shifting. No-load pressure drop is lower than 200 psi at flows of 25 gpm. Two-piece balance ring provides high mechanical and ...
High-pressure 30 disc valve motors offer high starting torque efficiency, low pressure drop, and smooth two-speed shifting. No-load pressure drop is lower than 200 psi at flows of 25 gpm. Two-piece balance ring provides high mechanical and volumetric efficiencies. They suit applications that require up to
30,000 lb-in. intermittent torque. At continuous pressure, flows are 45 gpm at 4500 psi; at intermittent pressure, flows are 70 gpm at 5070 psi; and maximum inlet pressure is 6000 psi.
Eaton Corp., (952) 937-7312,
www.hydraulics.eaton.com
