Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 05 01 2009 84225 Variabledi 00000056528
Variable-Displacement Pump
May 6, 2009
A4VG high-pressure pump for closed-circuit applications offers high power density to comply with global emission regulations. Nominal pressure is 6500 bar. It counteracts reduced speed of diesel engine and low input flow rates. ...
A4VG high-pressure pump for closed-circuit applications offers high power density to comply with global emission regulations. Nominal pressure is 6500 bar. It counteracts reduced speed of diesel engine and low input flow rates. Redesigned pump case can include sensors used to monitor swivel angle, high pressure, and rotational speed. Bowl-shaped design avoids high-pressure transitions at sealing points, and eliminates some sealing points entirely.
Bosch Rexroth Corp.
(610) 694-8298
www.boschrexroth-us.com
