Planetary-Gear Speed Reducers
April 9, 2012
Series 700 HYD-Drives is a combination of orbital motors and planetary gear reducers. They offer displacements from 41.36 to 341 in./rev3, output torque from 610 to 4960 lb-in. × 100 psi, maximum output torque from 19.883 to 114.080 lb-in. and maximum output speed from 128 to 30 rpm.
Series 700 HYD-Drives is a combination of orbital motors and planetary gear reducers. They offer displacements from 41.36 to 341 in./rev3, output torque from 610 to 4,960 lb-in. × 100 psi, maximum output torque from 19.883 to 114.080 lb-in. and maximum output speed from 128 to 30 rpm. Options include single and double stage reducers with a variety of ratios; direct mounted cartridge valve; spline, keyed, or flanged output shaft; and multi-disc brakes.
Young Powertech, (888) 465-3561
www.youngpowertech.com
