Motorized flow controls
Aug. 10, 2007
Generation II flow and pressure controls feature a planetary reducer and heavy-duty motor to deliver more torque with less backlash. Nine operating speeds from 1 to 48 sec allow travel from full-open to full-shut and vice versa. Command to the ...
Generation II flow and pressure controls feature a planetary reducer and heavy-duty motor to deliver more torque with less backlash. Nine operating speeds from 1 to 48 sec allow travel from full-open to full-shut and vice versa. Command to the controller is done with potentiometer, 4-20 mA, 0-10 V, or pwm signal. They are available in flow ranges from 0-3 gpm to 0–120 gpm at 100 psi. Motorized relief and reducing relieving valves are available in pressure ranges to 5000 psi and flows up to 15 gpm.
Source Fluid Power, (952) 368-3866, www.sourcefp.com
