Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 7128220pneumati 00000046667
Pneumatic valve manifolds
Sept. 24, 2007
Series VV061 Cube manifold comes with 6-mm wide, 3-port valves that operate small bore cylinders or serve as a pilot valve to actuate larger valves. They combine valve, printed circuit board, base, and fittings and consume 0.55 W in standard ...
Series VV061 Cube manifold comes with 6-mm wide, 3-port valves that operate small bore cylinders or serve as a pilot valve to actuate larger valves. They combine valve, printed circuit board, base, and fittings and consume 0.55 W in standard configuration and 0.23 W with power saving circuit using 24 or 12 Vdc. They have a 10-msec response time and are rated for flows of 0.004 and 0.008 CV in low- pressure version, suitable from vacuum to 44 psi pressure. SMC Corp. of America, (317)-899-4650, www.smcusa.com
