Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 05 01 2007 66459products01 00000042740
Condensate drain valve assemblies
May 15, 2007
Line of condensate drain valve assemblies are designed for use in compressed air systems for critical moisture drainage. Air-operated models incorporate a straight-through design with fewer components. This provides leak-tight sealing and ...
Line of condensate drain valve assemblies are designed for use in compressed air systems for critical moisture drainage. Air-operated models incorporate a straight-through design with fewer components. This provides leak-tight sealing and non-clog operation for lower cost and minimal maintenance. Solenoid-operated versions are smaller and offer longer life in high-temperature, high-humidity applications. Both versions come with standard timer range, elastomer, and voltage.
ASCO, Div. of Emerson, (800) 972-2726, www.ascovalve.com
