Expandable valve manifolds
May 4, 2012
VS manifolding valve product range improves design, maintenance and performance of pneumatic systems in industrial machines, by allowing expansion of the manifold in the field without tearing it apart or replacing it. Modular design allows expansion of single stations by up to 16 valves.
VS manifolding valve product range improves design, maintenance and performance of pneumatic systems in industrial machines, by allowing expansion of the manifold in the field without tearing it apart or replacing it. Modular design allows expansion of single stations by up to 16 valves. Expanding VS18, VS26 or VS45 valve manifolds takes only seconds using plug-in printed circuit board (PCB) technology. Three sizes of plug-in sub-base valves offer flows of 0.52 up to 4.2 CV.
Connections are simple, with a two-screw system for attaching the manifold bases.
They come with two unique spool technologies. Softseal spool achieves enhanced flow rates to maximize speed. Their glandless spool and sleeve delivers hundreds of millions of trouble-free cycles. Both can be incorporated in the same manifold to meet application-specific requirements. Accessories optimize air use and reduce costs by using sandwich regulators and flow controls, allowing for interruption-free valve exchange for easier maintenance and reduced downtime.
Norgren, (720) 283-5417, bit.ly/hp512norgren
