Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads 2013 01 Monnier Dsc 0469
High-flow pneumatic filters
Jan. 14, 2013
The 201-9202 series of high-flow filters from Monnier are available in particulate (3 µm element) or coalescing (0.01 µm) styles. They come with 3-in. NPT ports and NPT, BSPT and BSPP threads and are rated for flows of 1200 scfm at 100 psig with a 1.0 psig ∆P. Housing is heavy-duty cast aluminum.
The 201-9202 series of high-flow filters are available in particulate (3 µm element) or coalescing (0.01 µm) styles. They come with 3-in. NPT ports and NPT, BSPT and BSPP threads and are rated for flows of 1200 scfm at 100 psig with a 1.0 psig ∆P. Housing is heavy-duty cast aluminum. They are available with a manual or float drain. They are rated for temperatures to 175°F.
Monnier Inc., (810) 794-4935, bit.ly/hp113monnier
