Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 05 01 2010 85768 Valvemanif 00000058377
Valve manifold
May 11, 2010
The 410M series manifold accommodates 310 and 410 in-line solenoid valves. It can be mounted with 3-way and 4-way valves on the same manifold, with the 310 series mounting orientation determining the NC or NO ...
The 410M series manifold accommodates 310 and 410 in-line solenoid valves. It enables mounting both 3-way and 4-way valves on the same manifold, with the 310 series mounting orientation determining the normally closed or normally open function. Manifolds are available in 2, 4, 6, 8, or 12 station lengths. The 310 and 410 are 18-in. ported 3-way and 4-way direct acting solenoid valves. They have a 0.12 and 0.14 CV flow rate, respectively, and are rated for air at vacuum at 28-in. Hg to 125 psig.
Humphrey Products Co., (269) 381-5500, www.humphrey-products.com
