Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 9661newproducts 00000003450
Diaphragm vacuum regulators
June 27, 2005
Ultra-miniature single-stage diaphragm vacuum regulator is designed to control output vacuum from 0 psig to low vacuum regulation such as -1/2 psig. Lightweight design eliminates need for panel mounting. Constructed of brass and steel, with a 30 ...
Ultra-miniature single-stage diaphragm vacuum regulator is designed to control output vacuum from 0 psig to low vacuum regulation such as -1/2 psig. Lightweight design eliminates need for panel mounting. Constructed of brass and steel, with a 30 g weight and 35/64 in. height. Inlet and outlet ports are 10-32 UNF. Come with Buna-N standard seals. Panel mount thread, seals, and diaphragm materials optional.
Beswick Engineering Co. Inc., (603) 433-1188, www.beswick.com
