Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 06 01 2010 85873 Pneumaticp 00000058523
Pneumatic pressure sensors
June 11, 2010
Edited By Mary C. Gannon PQ series pressure sensors are designed for pneumatic applications typically found in robotics and material handling. They measure 32 30 42 mm and feature two programmable switching outputs or one switching and one ...
PQ series pressure sensors are designed for pneumatic applications typically found in robotics and material handling. They measure 32 30 42 mm and feature two programmable switching outputs or one switching and one diagnostic output. They can be connected to air lines through G-18 port using a 6 or 8-mm tubing adapter or a 18 in. NPT adapter. PQ7809 has a measuring range of -14.5 to 14.5 psi and PQ7834 has a measuring range of -14.5 to 145 psi. ifm efector Inc., (800) 441-8246, www.ifm.com/us
