Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 09 01 2009 84774 Pneumaticp 00000057057
Pneumatic pressure transducer
Sept. 14, 2009
Series 3300 pressure transducer is designed for low-pressure applications that demand small size, low cost, high accuracy, and stability. All-stainlesssteel wetted parts and all-welded construction make it compatible with harsh chemicals ...
Series 3300 pressure transducer is designed for low-pressure applications that demand small size, low cost, high accuracy, and stability. All-stainlesssteel wetted parts and all-welded construction make it compatible with harsh chemicals and environments. Available in pressure ranges from 15 to 250 psi, it operates in temperatures between –40° to 257°F. It is available in voltage, current, and ratiometric outputs.
Gems Sensors Controls
(800) 378-1600
www.gemssensors.com
