Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 05 01 2008 80336positionse 00000052788
Position Sensors
May 14, 2008
LP750 position sensors are hermetically sealed, frictionless, and replace linear potentiometers. Standard ranges of 4 to 25 in. are offered in a pre-calibrated, loop-powered 4-20 input/output or a nominal 24 Vdc input and 0 to 10 Vdc output. ...
LP750 position sensors are hermetically sealed, frictionless, and replace linear potentiometers. Standard ranges of 4 to 25 in. are offered in a pre-calibrated, loop-powered 4-20 input/output or a nominal 24 Vdc input and 0 to 10 Vdc output. They provide high stroke-to-length ratio, high resolution and repeatability, and low hysteresis. They have maximum nonlinearity error of ±0.25% fullscale output. Coil winding and digitally enhanced analog output enable a compact design.
Macro Sensors, (856) 662-8000, www.macrosensors.com
