Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 45439 Prods B0401 00000020953
Predictive flow meter
Feb. 21, 2007
Brass variable area flow meteroperates under pressures to 3500 psi and temperatures to 240° F. Indicator ring moves linearly for quick, direct visual reading and serves as a predictive tool by eliminating need for calculations or corrections. It ...
Brass variable area flow meteroperates under pressures to 3500 psi and temperatures to 240° F. Indicator ring moves linearly for quick, direct visual reading and serves as a predictive tool by eliminating need for calculations or corrections. It installs directly into horizontal or vertical lines or with inverted flow scale to monitor flow in a downward line. Accuracy is within ±2% full scale, with repeatability within 1% in any mounting direction.
Hedland, Div. of Racine Federated Inc., (800) 433-5263, www.hedland.com
