Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 10 01 2008 82597linearpng 00000054733
Linear Position Sensors
Oct. 9, 2008
LP 750 linear position sensors have a 3/4-in. diameter and are hermetically sealed to serve as long-life replacements for potentiometers. They are available in standard ranges of 4 to 25 in. and come with a pre-calibrated, loop-powered ...
LP 750 linear position sensors have a 3/4-in. diameter and are hermetically sealed to serve as long-life replacements for potentiometers. They are available in standard ranges of 4 to 25 in. and come with a pre-calibrated, loop-powered 4-20 input/output or nominal 24 Vdc input, 0 to 10 Vdc output. Maximum linearity error is ±0.25% of full-scale output. They suit long-stroke applications where sensor length must be as long as the stroke of the device.
Macro Sensors, (856) 662- 8000, www.macrosensors.com
