Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 02 01 2005 Mronews0601png 00000003226
Handheld force gauges
Feb. 1, 2005
The HFG-45 is a pocket-sized digital force gauge. Engineering units include lb, oz, kg, N, or kN for loads to 45 lb with full-scale accuracy of 0.5% in either tension or compression. Can be used for continuous or peak capture measurements.
The HFG-45 is a pocket-sized digital force gage. Engineering units include lb, oz, kg, N, or kN for loads to 45 lb with full-scale accuracy of 0.5% in either tension or compression. Can be used for continuous or peak capture measurements.
Transducer Techniques Inc.
(800) 344-3965
www.transducertechniques.com
