Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 07 01 2009 84544 Flowtransm 00000056820
Flow transmitter
July 13, 2009
MR flow transmitter combines digital signal processing with piston-type variablearea flowmeter technology. Solid-state device senses magnetic-piston-assembly movement and provides accurate, repeatable flow measurement. It has no mechanical ...
Solid-state device senses magnetic-piston-assembly movement and provides accurate, repeatable flow measurement. It has no mechanical linkages; non-contact sensor electronics; digital flow rate and total flow indication; proportional analog output; and low-power design for two-wire loop powered operation. It provides 0 to 5 and 0 to 10 Vdc voltage and 4-to-20-mA current loop outputs.
Hedland
Div. of Racine Federated Inc.
(800) 433-5263
www.hedland.com
