Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 05 01 2009 84209analogdevi 00000056499
Modules connect analog devices to fieldbus networks
May 6, 2009
A high-density I/O block from Acromag, Wixom, Mich., features a 48- channel combination of analog inputs and outputs for the company’s Ether- Stax Ethernet I/O series. Units interface dc current or voltage signals and connect to 7B or 8B ...
A high-density I/O block from Acromag, Wixom, Mich., features a 48- channel combination of analog inputs and outputs for the company’s Ether- Stax Ethernet I/O series. Units interface dc current or voltage signals and connect to 7B or 8B isolated signal conditioner modules.
Models ES2151 and ES2152 accommodate 16 dc current inputs (±20 mA, 0-20 mA, or 4-20 mA), 16 voltage inputs (±5 V and ±10 V), and either 16 current or voltage output signals, respectively, to interface sensors and actuators to an Ethernet control network.
Modbus TCP/IP and UDP/IP protocol communication and peer-to-peer messaging are supported. A DB25 input port connects a rack of signal conditioning modules to monitor temperature, frequency, load cell, and other sensors. ES2152 models also have a DB25 output port to control analog output modules. High resolution (0.1%, 100 msec) 16-bit A/D and D/A scanning updates all channels in less than 10 msec.
A DB25 port allows alternate voltage inputs from a 7B or 8B signal conditioning module rack supporting nearly 100 additional input types with channel-to-channel isolation. Scaling registers are configurable on a perchannel basis.
The inputs have a configurable sample averaging function, and each channel has a non-volatile integrator/ totalizer for additional signal processing tasks. On-demand self-test verifies calibration, and a built-in loop-back circuit provides output validation.
A failsafe relay provides alarm output on a power or link-loss failure. A hardware watchdog timer can send outputs to a failsafe state or hold the last value if communication fails.
Stackable, high-density packaging enables installation of nearly 150 I/O points in a 8- by 7-in. footprint. The design is ideal for mounting on DIN rails, walls, or directly on machinery. Pluggable terminal blocks make for easy installation and servicing.
For more information, call (248) 295- 0880 or visit www.acromag.com.
