Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 38560 Prods0102j 00000017701
Hydraulic cylinders
Oct. 18, 2006
CHE hydraulic cylinders are compact and flexible. They require less mounting space than tie rod cylinders, with many mounting configurations, porting options, and rod end styles. Corrosion-resistant aluminum body is available in 20 to 100 mm ...
CHE hydraulic cylinders are compact and flexible. They require less mounting space than tie rod cylinders, with many mounting configurations, porting options, and rod end styles. Corrosion-resistant aluminum body is available in 20 to 100 mm bore sizes and accepts sold state and reed switches that mount within the cylinder envelope, for mid-stroke or end-of-stroke piston position sensing. They are rated for pressur to 140 bar, depending on bore size.
Parker Hannifin Corp., US Industrial Cylinder Div., (847) 298-2400, www.parker.com/cylinder
