Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 12866 Pneumatic P 00000006061
Metric tie rod cylinders
Dec. 30, 2005
CA2 metric cylinders use aluminum die-cast covers, making them lighter than previous versions. Increased cushioning and improved floating cushion seals reduce jerky movements of piston rod at lower operating pressures and increases seal life. ...
CA2 metric cylinders use aluminum die-cast covers, making them lighter than previous versions. Increased cushioning and improved floating cushion seals reduce jerky movements of piston rod at lower operating pressures and increases seal life. Kinetic energy absorption is increased by 30% during cushioning at end of stroke.
SMC Corp. of America, (317) 899-4650, www.smcusa.com
