Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads 2014 07 Peninsular
Cylinder configurator generates ready-to-use drawings
March 9, 2009
The Peninsular metric model IHP Hydraulic Cylinder Configurator now provides 2-dimensional drawings and 3-dimensional models.
The Peninsular metric model IHP Hydraulic Cylinder Configurator provides 2-dimensional drawings and 3-dimensional models. The Cylinder Configurator, accessible through Peninsular’s website, makes ordering cylinders easier by having users answer questions from drop-down menus, thus eliminating the need for confusing cylinder catalogs and complex engineering data.
Click on image for larger view.
Peninsular’s Cylinder Configurator provides quick and easy cylinder ordering and solid model CAD drawings that can be downloaded immediately. In addition, 2-dimensional flat line drawings with dimensions may be instantly received within minutes after the cylinder configuration is complete. In addition, the cylinder part number, mounting style, cylinder bore, piston rod diameter, rod threads, accessory and seal kit part numbers, port and cushion locations are also presented in the title block of every configured 2-D drawing. Details on metric accessories and cylinder repair kits are also included.
For more information, visit www.peninsularcylinders.com.
