Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads 2014 08 No Pak
Class 3 NFPA Hydraulic Cylinders
June 4, 2014
NFPA interchangeable high pressure hydraulic cylinder product line. Time-proven 3-groove piston with cast iron rings outboard and a "GT" positive seal in the center groove. Each assembly is proof tested (as a pressure vessel) at 5,000 psi. More than 20 mounting styles in 14 bore sizes from 2½ to 5 in. are standard.
NFPA interchangeable high pressure hydraulic cylinder product line. Time-proven 3-groove piston with cast iron rings outboard and a "GT" positive seal in the center groove. Each assembly is proof tested (as a pressure vessel) at 5,000 psi. More than 20 mounting styles in 14 bore sizes from 2½ to 5 in. are standard. Standard rod diameters range from 2½ to 3½ in.
Galland Henning Nopak, (414) 645-6000, [email protected],
www.nopak.com
