Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 70652 Prods0103j 00000046170
Pneumatic couplings
Sept. 5, 2007
Range of quick disconnect couplings is designed for use in pneumatic applications. They can be used to connect air tools and air hoses to a compressed air system. PAC-20 air coupling and PAP-20 air probe are rated to 300 psi and feature 1/4-in. NPT ...
Range of quick disconnect couplings is designed for use in pneumatic applications. They can be used to connect air tools and air hoses to a compressed air system. PAC-20 air coupling and PAP-20 air probe are rated to 300 psi and feature 1/4-in. NPT female threads at each end. They can be used with existing 50-ft. utility hoses that are pre-assembled with a 1/4-in. NPT male fitting.
Pirtek USA, (888) 774-7835, www.eta1houronsite.com
