Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 06 01 2010 85874 Swiveladap 00000058524
Swivel adapters
June 11, 2010
Edited By Mary C. Gannon Swivel adapters adjust the line of sight with gauges, transmitters, and valves. They rotate 360° to allow the connected instrument to be positioned in the desired orientation. Pressure connection is achieved with a tapered ...
Swivel adapters adjust the line of sight with gauges, transmitters, and valves. They rotate 360° to allow the connected instrument to be positioned in the desired orientation. Pressure connection is achieved with a tapered cone style compression fitting by tightening the swivel hex nut. They feature all 316 stainless steel construction, and are standard with in. NPT male process – in. NPT female instrument connections.
Noshok Inc., (440) 243-0888, www.noshok.com
