Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 43125 Usefulprod 00000019409
Swivel connectors
Nov. 20, 2006
Triple-Lok 37° flare female connections position the sealing surface away from tip of male nose, which tolerates surface imperfections at the tip, protects the nose during assembly, and prevents gouging of the female cone seat. Dual-angle ...
Triple-Lok 37° flare female connections position the sealing surface away from tip of male nose, which tolerates surface imperfections at the tip, protects the nose during assembly, and prevents gouging of the female cone seat. Dual-angle seat accepts 37° and 45° flare fittings. They feature 72% higher pressure ratings than SAE J514 fittings, but with no difference in overall swivel nut size or fitting body and no change in torque or assembly method.
Parker Hannifin Corp., Tube Fittings Div., (614) 324-8239, www.parker.com/tfd
