Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 712664flarepng 00000046655
Flare-fitting seals
Sept. 24, 2007
Leak-free seals fit flared fittings of 30°, 37°, and 45°. They are rated for –65° to 1200° F and available in 304 and 316 stainless steel and copper for use with all hydraulic fluids. Sealing rings compress when tightened, maintaining faces’ ...
Leak-free seals fit flared fittings of 30°, 37°, and 45°. They are rated for –65° to 1200° F and available in 304 and 316 stainless steel and copper for use with all hydraulic fluids. Sealing rings compress when tightened, maintaining faces’ compression during load and temperature cycles and external vibrations. They are stamped in all 37° sizes, from 3/16 through 2 in.; seals for 45° fittings are also available.
Flaretite Inc., (810) 750-4140
www.flaretite.com
