Bio-oil sensor
Aug. 13, 2013
The new bio-oil sensor uses an oil-condition sensor to determine which type of oil is in a reservoir.
The new bio-oil sensor uses an oil-condition sensor to determine which type of oil is in a reservoir. The sensor comes with a rechargeable battery and an optical display to help users determine the type of oil on site — mineral oil, mixture, or bio-oil. Two digital indicators also display permittivity and relative humidity. The case comes with an RS-232 interface for subsequent analysis and documentation of the data. Measured values can
directly be transferred to a PC for processing. Two different measurement methods can be applied: a quick determination or a detailed measurement and issuing of a value table.Argo-Hytos Inc., 419.353.6070, www.argo-hytos.com
One Simple Way To Remove Water From Hydraulic Oil
June 22, 2015
If you've worked with hydraulic equipment for any length of time, it's likely that you've come across a hydraulic system with cloudy oil. Oil becomes cloudy when it's contaminated...
How To Size A Hydraulic Tank
March 24, 2015
The rules of thumb for reservoir size differ for open and closed circuits. For a conventional reservoir used in open circuits the general rule is a tank oil capacity of 3 to 5...
