Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 03 01 2005 Prod0104png 00000003249
Locking cylinders
March 1, 2005
Series CCA advanced locking cylinders feature integral Amlok rod clamp, developed to control over travel, drifting, bouncing, and reverse traveling. High locking force will hold rod in any mid-stroke position. Since locking is accomplished mechanically by
Series CCA advanced locking cylinders feature integral Amlok rod clamp, developed to control over travel, drifting, bouncing, and reverse traveling. High locking force will hold rod in any mid-stroke position. Since locking is accomplished mechanically by a spring and unlocked by air pressure, loss of air pressure will cause the unit to lock. Holding force depends upon the rod and piston diameter; can be multiplied by adding additional clamps or exchanging springs and increasing release pressure.
Advanced Machine & Engineering Co., (815) 962-6076, www.ame.com
