Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 24708 Products02 00000013950
Plastic netting
Aug. 10, 2006
Polynet provides protection against damage to exterior surfaces of machined, polished, plated, coated, and threaded areas. It does not retain moisture and is easy to apply and remove. It is available by the roll or cut to size in low-density ...
Polynet provides protection against damage to exterior surfaces of machined, polished, plated, coated, and threaded areas. It does not retain moisture and is easy to apply and remove. It is available by the roll or cut to size in low-density polyethylene and comes in a standard or heavyduty weight.
Polymer Molding, (800) 344-7584, www.polymermolding.com
