Moog Inc.'s facility in the United Kingdom first supplied the Formula One industry with custom versions of miniature servovalves used on aircraft, missiles, and spacecraft. But these were soon replaced by products tailored to the rigors of Formula One.
Car designers are weight watchers
One key demand of motorsport engineering is designing for absolutely minimum weight, according to Martin Jones, the company's motorsport market manager. "The weight-watching culture is particularly prevalent in Formula One, where much effort is expended to shave a few grams from even the smallest components," offered Jones. Curiously, all current Formula One cars carry ballast to achieve the minimum allowed weight of 600 kg. However, teams can gain considerable competitive advantage by maximizing the ballast and placing it low in the vehicle, which aids handling, explains Jones. It also facilitates on-track setup procedures, as moving the mass fore or aft alters the vehicle center of gravity.
Jones continued, "Hydraulics is absolutely unique in terms of power density, and the little valves we supply to Formula One can control 5 hp of power at a fraction of the size and weight of equivalent electric motors."
Moog's E024 subminiature servovalves, for instance, weigh only 92 g, less than half the mass of the company's smallest aerospace servovalve. In today's Formula One cars they're typically used on the clutch, gearshift, throttle, and differential.
The valves' small size — the E024's spool has a 4-mm diameter — and steel construction permits thin walls without excessive internal stresses, even at 280 bar. This lets designers build in a significant safety factor with minimum impact on weight.
Valve drivers in the car's ECU (electronic control unit) supply a ±10-mA signal that is varied to produce a proportional valve response. An electric torque motor that rotates ±2° drives the pilot stage. Considerable design effort on details such as the inertia of moving parts, magnetic field strength, and air gaps results in a response time of less than 1 msec for the electromagnetic stage, explained Jones. It controls the tiny second-stage spool, giving total step response of only 2.8 msec.
Taking the heat
Heat is another issue. Formula One hydraulics generally operate at temperatures to 135°C, versus about 60°C on typical industrial systems. In any hydraulic circuit, throttling flow generates heat. But most industrial systems include large reservoirs or heat exchangers to keep fluid temperature within operating limits. In contrast, Formula One hydraulic reservoirs hold only 20 to 30 cc. With no significant oil mass in the system, temperature rises quickly.
