Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product Pneuprodpdf0104j 00000000358
Push-fit fittings
April 3, 2005
Push-fit fittings and pipe connect a compressed air source to takeoff points for point-of-use equipment. Compressed air systems can be installed quickly with no need to prepare threaded pipe or apply solvent. The fittings are made of tough ...
Push-fit fittings and pipe connect a compressed air source to takeoff points for point-of-use equipment. Compressed air systems can be installed quickly with no need to prepare threaded pipe or apply solvent. The fittings are made of tough engineered plastics or brass. They are designed for use with the company's nylon pipe, but can also be used with copper or aluminum pipe.
John Guest USA Inc., (800) 945-4872,www.johnguest.com
