Rota Limited
Bury, Manchester BL8 2BD
COMPANY OVERVIEW
About Rota Limited
Contact
Wellington Street
United Kingdom
https://rota-eng.com/
(972) 359-1041
More Info on Rota Limited
Rota Limited develops sensor and related technologies which can be incorporated into or alongside hydraulic cylinders utilized in a range of applications including construction and agricultural equipment, oil & gas, and more.
As of May 2023, Rota has changed its company name from Rota Engineering Limited to Rota Limited; its company registration number, ownership, bank details and everything else remains unchanged.
Articles & News
297946586 © Andriy Dovzhykov | Dreamstime.com
hydraulic hoses with pressure sensor
Feb. 12, 2024
Benefits ranging from improved precision and control to enhanced machine monitoring are possible when integrating sensors into fluid power systems.
Vermeer
Use of Rota linear position sensors for hydraulic cylinders in a Vermeer pile driver enables better accuracy during solar field installations by ensuring piles are driven at the precise angle desired.
Sept. 26, 2023
Use of linear position sensors in the hydraulic cylinders of a pile driver ensure accurate placement of piles for solar field installations.
245019714 © Cherezoff | Dreamstime.com
Several performance benefits can be achieved when pairing sensors and software with motion control systems.
May 31, 2023
Integration of sensors and software into hydraulic, pneumatic and electronic motion control systems is enabling improved controllability, efficiency and other benefits.
Request More Information
All content from Rota Limited
Rota Engineering
The LL Series transducer features an ultra-robust design.
Feb. 9, 2023
The independent mount LL Series transducer provides a robust alternative to in-cylinder position transducers.
